Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#8
Re: Any ideas?
Fenix_Longbow
Posted on: 2010/2/24 2:51
About 300Nm correct? im a little rusty... That means i definetly need to upgrade the axles as well. Any suggestions compatible with the 9"?
#7
Re: Any ideas?
Posted on: 2010/2/24 2:08
Axles are not rated for horsepower, but are for torque.
The H165 diff and axles can reliably take about 225 lb. ft. of torque
#6
Re: Any ideas?
Fenix_Longbow
Posted on: 2010/2/24 1:41
Ok thanks. My next question is: How much power can the standard axles take? If the datto doesnt sell im likely thinking around the 200rwkw+ vicinity
#5
Re: Any ideas?
Posted on: 2010/2/23 21:57
R31 is not the easiest to fit.
Something with original leafs is easier. Ford 9" is perhaps the easiest, can be made to order for Datsun 1200.
#4
Re: Any ideas?
Fenix_Longbow
Posted on: 2010/2/23 9:46
Im thinking along the lines of a shortened R31 axle, shortened shaft and either a CA or RB gearbox. I guess something thats going to be strong but the easiest to fit. Cost comes third...
#3
Re: Any ideas?
Fenix_Longbow
Posted on: 2010/2/21 7:49
CA18det in it with a T28BB turbo and Microtech ECU.
#1
Any ideas?
Fenix_Longbow
Posted on: 2010/2/19 20:56
Morning guys,
My car is nearly on the road- passed its blueslip no worries, :)- and now im sorta faced with continuing to modify it. Currently it has the standard rear axles with a H165 diff and an R30 gearbox, what im thinking is a stronger rear axle, a proper LSD and i would like to have a ca18 gearbox unless i can fit a tougher gearbox- maybe an r32 or r33? Im unsure of the specifics but i imagine that the shifter will be pushed back, regardless of where i go, maybe a shortened tailshaft, r31 rear axles and disc brake conversion? Anyways, what do you guys think? You can view topic.
