Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#26
Re: A12 turbo wont rev - Update got it runnning
Fenix_Longbow
Posted on: 2010/2/24 23:48
Its only a 1.2ltr with a turbo intended for a 2ltr engine... it will be laggy. Getting properly tuned though will help minimize it :P
#25
andy-roo
Posted on: 2010/2/24 22:35
ok sweet thanx my my email is buyadatsun@hotmail.com wen ever u do do it
#24
DAT012
Posted on: 2010/2/24 20:28
Ill take some pictures of the boost ref line next time I got the carby hat off, but basically all I did was drill along the blank passage that runs along the top of the float bowl and then drill into it from underneath, then I used devcon to glue in a piece of 5/16 bundy tube into the hole, not the neatest way to do it but works a treat
#23
andy-roo
Posted on: 2010/2/24 19:25
thats good u got it sorted
any chance u hapen to have pics on how u attached ur boost reference line to ur float bowl?
#22
ssskiwi
Posted on: 2010/2/24 11:25
Good to hear! Nice work.
Sounds like time to get the compressed air out to clear out the other body's passages.
#21
supafatto
Posted on: 2010/2/24 11:10
good work :)
#20
DAT012
Posted on: 2010/2/24 10:17
Changed the bottom half of the carby this arvo with one that i knew worked and this fixed the problem. Took it for a quick drive and it ran pretty sweet but it seemed fairly laggy
#19
DAT012
Posted on: 2010/2/23 20:42
I've tried it hot or cold it makes no difference, im going to try a different carby on it tonight and see what happens
#18
andy-roo
Posted on: 2010/2/23 20:32
is it just doing this wen its cold? have u let it idle to warm then rev? because mine will do that until warm i am running the same sort of setup but without the boost reference line and mine is fine only leans a little up top like 8-9g but is not properly jetted yet i had fuel problems wen i first did it with a 32/36 weber but then i changed to a 180 holley and it was fine but i believe it was just my weber
#17
tommo73
Posted on: 2010/2/23 11:21
seen as the carby is the only questionable part
i would look there, even if u rebuilt it use your hand to choke the carby while its running and see if it revs then sounds like lack of fuel primarys idle jets are fine primary main jet blocked You can view topic.
