#5 Re: 2 ca's one with engine cooler one without?
supafatto Posted on: 2010/4/19 12:43
like this
det block and my 2 de blocks dont have it
jpg  19042010247.jpg (80.26 KB)
10308_4bcc41aeb8806.jpg 864X648 px
#4 Re: 2 ca's one with engine cooler one without?
tommo73 Posted on: 2010/4/19 12:39
de no cooler
det has a oil cooler( water to oil )
would run oil cooler cause thay dont hold much oil
and oil gets hot under boost conditions
#3 Re: 2 ca's one with engine cooler one without?
supafatto Posted on: 2010/4/19 12:31
no cadet i have has one 2 im not sure wat it for ill take a pic
wheres pigdog when u need him
#2 Re: 2 ca's one with engine cooler one without?
ddgonzal Posted on: 2010/4/19 6:04
engine cooler? Do you mean oil cooler adapter?
#1 2 ca's one with engine cooler one without?
mattkinsela Posted on: 2010/4/19 5:36
as written before i have 2 ca's one has an enginr cooler mounted on the block where the filter screws on and one doesnt. tried to find some info on this but done no good.thinking of swapping the cooler setup to the engine without it (engine with cooler is shagged). does anyone run one of these engines without the cooler without any problems? will probably end up fitting the cooler for better reliability but was just curious.
