#11 Re: need help im a newbie
estyre Posted on: 2010/4/26 15:21
eeewww its dodgy though ,but it looks better than rust holes
a mate of mine did put checker plate in his ute with clear cylastic and hes a panel beater !!
#10 Re: need help im a newbie
LittleFireyOne Posted on: 2010/4/26 15:11
my blue ute had the dodgey checkerplate welded over rust
#9 Re: need help im a newbie
estyre Posted on: 2010/4/26 14:47
haha that is so dodgy joel !! ,if i was you i would just buy a cheap welder and do as much panel work as possible ,and for the floor i would just buy a big piece of 2mm plate and then cut the floor out and drop the new piece in ,but i would make it thicker than standard cos it wont get little dents in it like the standard floor and will probly stiffen the back of the ute up and i might handle a little better ,then you can still put the checkerplate for look
welcome to Datsun1200.com !!
#8 Re: need help im a newbie
popo1200perth Posted on: 2010/4/26 14:30
buy yourself some checkerplate steel and cut it to fit.. it looks awesome. just put it over the top after you have rust gaurded the original floor
#7 Re: need help im a newbie
levey Posted on: 2010/4/26 13:44
Its not too hard to learn how to weld, I taught myself with a $300 Ozito gasless Mig welder.
#6 Re: need help im a newbie
Dat_One Posted on: 2010/4/26 13:38
what should i do about the floor of my tray is it easy to repair or replace it has some small holes from rust damage
#5 Re: need help im a newbie
Dat_One Posted on: 2010/4/26 13:34
i want to do the engine last thou because im still on my P plates
#4 Re: need help im a newbie
Dat_One Posted on: 2010/4/26 13:33
brisbane
#3 Re: need help im a newbie
levey Posted on: 2010/4/26 13:17
Drop an A15 in it, you will be happy!
#2 Re: need help im a newbie
popo1200perth Posted on: 2010/4/26 13:11
what sort of engine mods do you want to achieve? motor wise you can pretty much do anything you want mate. as long as you have the money to spend you can do alot of things. bodywise panels are pretty cheap if it is too rusty to be saved. this is the best place to ask ey where abouts are you situated?
