Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#66
Re: 5 Speed adaptors? Which gearbox to use?
D
Posted on: 2010/6/14 5:41
There is also the alfa boxes but these boxes are quite rare now
while the T5 from a Ford ute with a 6 cylinder is only 34kg and gearsets are often from Mustang v8s in the early Word class boxes. ratios are pretty good if not excellent!!! 2.95, 1.95, 1.34, 1, 0.73 (also .65 overdrive available!)
#65
ssskiwi
Posted on: 2010/6/12 8:06
After surfing TradeMe over the ditch, how about the Fiat 5 speed as per this ad?
http://www.trademe.co.nz/Trade-Me-Mot ... iat/auction-295161150.htm Has a seperate bell housing and already fitted with a straight cut C/R 1:1 5th gear set.. $1500 South Pacific Peso's = approx $1200 AUD plus 150 or so in freight..
#64
LittleFireyOne
Posted on: 2010/5/19 15:25
Slap me with the serious hand wont yas, it was partly a southpark joke from the somalian pirate episode :P
I didn't consider the gearboxes had rubbish 4wd ratios, though you could just use 3rd and 4th...
#63
jmac
Posted on: 2010/5/19 14:47
Gotta be honest, I wouldn't try this option even if the boxes were free. I don't wish to be overly negative about things, but China is not the place one normally assosciates with quality control and the like. The fact is thigs are made cheaply thee. No employee is going to give a damn when they earn a few dollars a day.
This is a difficult process (imho gear manufacturing/machining/hardening is about the hardest mechanically based sub section of auto manufacturing) and there's a reason that Albins Gears http://www.albinsgear.com.au/ charge what they do (and if the actual costs of developing an alternate ratio set for any new gearbox with relatively limited sales potential, they aren't pocketing much profit at all), and furthermore that there's no shortage of racers who do business with them. It requires massive knowledge, expensive machinery, the best raw materials and significant experience to do it right
#62
D
Posted on: 2010/5/19 14:28
A friend and I been down this route and unfortunately even for 100 gearboxes
they are not interested in making new gears to replace the ridiculous 4x4 ones. Imagine 4:3 or 4:1 for first no thanks. Their reply was the tooling for such and exercise is excessive and cannot be guaranteed unless we are willing to spend money on quality testing for each newly fabricated gear in a separately formed process shift line and the ability to pay 10% upfront for an order of minimum 1000 units.
#61
LittleFireyOne
Posted on: 2010/5/19 8:22
*runs into room exhausted...
YOU GUYS!! I saw a link on pf for cheap Chinese made gearboxes for thier copycat cars like the great wall ute and stuff. the prices are somewhere around $250US and above but for new boxes that's not bad. cheap gearboxes for chinese copy cars
#60
D
Posted on: 2010/5/19 3:53
I like the shifter mechanism and its compact size without the girth of the stumpy.
#59
PIGDOG
Posted on: 2010/5/19 0:23
interesting. that comparison pic is to a silvia box im guessing, cant say i can tell the differnce between a silvia and a skyline 71c without having them side by side
so the d21 box looks to between a stumpy and 71b in length wonder how much they go for
#58
D
Posted on: 2010/5/18 13:52
True true, but the length available is not the same as the 1200 allows.
In the 1000 you sit a little forward compared to the 1200. Im toying with the idea of finding a Nissan D21 gearbox with Bluebird s3 ca20e 71 series internals. Here are the pics of the box from the d21 its supposed to weight 35kgs. The bluebird 71b series box has supposedly a 3.01 or 3.3 first which would be better than the 3.9 or whatever the d21 is. This d21 is the shorter one in the pic and has the 71c type of gear shifting mechanism which would be better than the bush and pin type. It is also an alternative to the rare stumpy r30 box.
#57
PIGDOG
Posted on: 2010/5/18 6:30
anything will fit with a big enough hammer, or a 9 inch and welder
