#7 Re: reco boxes worth?
DJF280 Posted on: 2010/5/16 14:52
For any one in Sydney i highly recommend SPEEDY DIFF AND GEARBOXES in mount pritchard. contact Tony on 9822 0882 He is a great bloke and i have been using him for years
#6 Re: reco boxes worth?
PIGDOG Posted on: 2010/5/15 8:32
i got all my bearings from a local bearing supplier, i'd already pulled the box apart and written down all the bearing numbers though. but think he had a book that listed all the numbers for different things and what not
#5 Re: reco boxes worth?
ssskiwi Posted on: 2010/5/15 5:33
Getting my 60 series done for $400, new bearings, synchros and seals. Will be good as new
#4 Re: reco boxes worth?
Fenix_Longbow Posted on: 2010/5/15 4:23
Nice info! Thanks for that Pigdog... Where did u get your parts for the box? I think the synchros are going in 2nd gear and was curious to know where to get parts for them...
#3 Re: reco boxes worth?
PIGDOG Posted on: 2010/5/15 3:12
usually you can get away with just new bearings if its still changing gears fine, i rebearinged my r30 box for under $250. not the hardest thing to pull a box apart and put it back together, did the first one with my dad and the second one by myself. even then when its apart syncros are pretty easy to replace if you can get some new ones...dont know if you are supposed to do anything else when you replace syncros though
ask revhead, he works for hollinger and builds gearboxes for a living
#2 Re: reco boxes worth?
Fenix_Longbow Posted on: 2010/5/15 1:54
Too much mate... What most places do nowadays is u send them your box and they will send you a rebuilt unit in return. Can be anywhere from $600+ depending on which gbox. For a w58 you should be looking down the barrel of a $7-800 swap-over. To get them rebuilt your looking more than that... round a grand. I got priced $1200 for rebuilding the R30 gearbox of mine... but that is around where i live.
#1 reco boxes worth?
datto13b Posted on: 2010/5/14 22:57
how much is to reco gearboxes these days? W58 supra
as mine is starting to make noises...
