#5 Re: best spot for boost gauge line?????
waz1200 Posted on: 2010/6/3 13:38
there is a spot just after the throttle body for 1 on inlet manifold, dont tee into others. option 2 get a threaded nipple with a m6 by 1.25mm thread drill into ur manifold 5mm drill bit tap thread, and bam u have a a vaccum source just for ur boost gauge remember to put grease on end of drill bit to catch all swarf n a vaccum cleaner
#4 Re: best spot for boost gauge line?????
bones Posted on: 2010/6/3 2:21
Into the inlet manifold/plenum. You want the ACTUAL boost going into the motors intake runners. Never T into anything else, because if you have a boost leak on the "anything else" or the guage hoses, you got problems
#3 Re: best spot for boost gauge line?????
go1200 Posted on: 2010/6/2 23:18
T it off the fuel pressure reg
#2 Re: best spot for boost gauge line?????
tommo73 Posted on: 2010/6/2 15:06
boost guage shold hook to manifold
#1 best spot for boost gauge line?????
bugsie Posted on: 2010/6/2 11:56
as it says.. just got a boost gauge for my ca and want to know the best spot to hook up from???? of the line from the wastegate????
