Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#14
Re: CHARCOAL CANISTER
Posted on: 2010/6/28 18:17
Return line discussed in: http://datsun1200.com/modules/newbb/v ... hp?topic_id=46442&forum=1
Let's keep this topic about the charcoal canister
#13
waz1200
Posted on: 2010/6/28 12:12
where is the return line on the standard 1200 ute tank?? please help
#11
Posted on: 2010/6/23 23:27
I dunno for sure, but it should be able to go on any intake fitting which is as large as the Purge Hose on the canister.
The diaphragm on the canister controls the release to the engine, so that it does not create a vacuum leak. The vacuum hose goes to the distributor vacuum port. Dunno where/if a CA18 has this. ![]() It's only three line on the 1200's canister, not too difficult.
#10
go1200
Posted on: 2010/6/23 23:05
Anyone one know which vacuum port is for the charcoal canister on a ca inlet manafold
#9
Posted on: 2010/6/23 22:40
#8
Posted on: 2010/6/23 18:54
Yes, that is Fume Control. It prevents the petrol fumes from entering the atmosphere.
Datsun1200.com wiki has details: http://datsun1200.com/modules/mediawi ... ex.php?title=Fume_Control In older 1200s, the valve at the front goes to the air cleaner. In newer 1200 utes, it goes to the Charcoal Cannister.
#7
waz1200
Posted on: 2010/6/23 14:45
can anyone explain wat all these pipes do?
#6
ANGE
Posted on: 2010/6/4 7:56
my understanding of it, is that you need to run your fuel tank vent into
the canister and then into your intake manifold via a 1 way valve.. (usually via the pcv system) the cannister is just there to store any vapour while there is no vacuum to recyle it..
#5
Fenix_Longbow
Posted on: 2010/6/4 2:58
I have never had one on my 1200 and it was engineered...
