#4 Re: Measure your Combustion Chambers & Piston Dish - FS: Measuring kits
clyons8 Posted on: 2010/7/7 5:27
Red food dye and water. Helps define any left over air bubbles/pockets. Use a stick of chap stick to provide a seal around the chamber/piston dish.
I got rid of the syringes this morning, so forget about the 15.
So if anyone wants a perspex 6mm cc plate, just say so....... I have about 48 pieces here left over from an architectural model (wouldn't mind a couple $ for each though just to recoup costs!)
I can drill them for you or you can drill them.
#3 Re: Measure your Combustion Chambers & Piston Dish - FS: Measuring kits
Posted on: 2010/7/7 3:51
ribeena or auto trans fluid?
#2 Re: Measure your Combustion Chambers & Piston Dish - FS: Measuring kits
clyons8 Posted on: 2010/7/7 0:08
Anybody? $15 including postage.
#1 Measure your Combustion Chambers & Piston Dish - FS: Measuring kits
clyons8 Posted on: 2010/7/6 13:17
Is anyone interested in some cc plates to measure their combustion chambers and piston dish?
These figures can help to calculate compression ratio.
I cut a few out of a nice and thick 6mm sheet (high quality) that I had and each piece measures 100 x 100mm. I also have some spare syringes left over from a pack that I bought.
I figured I could include maybe a 50cc and 10cc syringe and the plate drilled already unless you want it blank.
I intended to use the 50cc syringe to check consistencies when porting.
Only about 4 sets here, can make more.
Anyone interested??? Send me a PM.
jpg  CC plate 1.JPG (180.17 KB)
7952_4c331dfa6a59b.jpg 1277X958 px
jpg  CC plate 2.JPG (100.19 KB)
7952_4c331e16e4b56.jpg 1277X958 px
jpg  CC plate 3.JPG (95.53 KB)
7952_4c331e723dafd.jpg 1277X958 px
jpg  CC plate 4.JPG (92.72 KB)
7952_4c331e8401923.jpg 1277X958 px
jpg  CC plate 5.JPG (96.61 KB)
7952_4c331e96e4292.jpg 1277X958 px
