#6 Re: AE86 Inserts in B110 struts
bezman Posted on: 2010/7/21 15:47
Check out these coilovers from Stance
http://www.felonyperformance.com/stance-ae86.html
WOW!!
but at ~1700 USD!!!!
but you get full coilovers, camber/castor adjustable pillow ball top mounts and spacers.. hmmmmm too bad we cant use the rear spring..
#5 Re: AE86 Inserts in B110 struts
armiee Posted on: 2010/7/21 14:47
Yeah my brother's got a 1972 Celica with supra struts, him and i are looking into them when the time is right
#4 Re: AE86 Inserts in B110 struts
bezman Posted on: 2010/7/21 14:18
hey thanks! that cleared it up - was going to buy some D2 32 way adjustable strut inserts from ebay for the AE86.. still watching em as i have both B110 and 280z struts
#3 Re: AE86 Inserts in B110 struts
armiee Posted on: 2010/7/21 10:16
Don't know if this will help :
http://otomoto.com.au/HDSystems/sleevekits.htm
#2 Re: AE86 Inserts in B110 struts
nzdatman Posted on: 2010/7/21 7:44
I haven't read the wiki but I think the datsun legs are 45mm OD. Therefore a 43mm insert will not fit inside them. 280ZX struts are 50.8mm OD so the 43mm inserts should fit in them but you'd want to measure the ID of the ZX leg first to make sure
#1 AE86 Inserts in B110 struts
bezman Posted on: 2010/7/21 7:27
AE86 inserts fit b110 struts or 280zx struts?
I ask cause i am getting some mixed info
AE86 toyota inserts are ~43mm and b110 datsun inserts are ~45mm according to the wiki so they should work right??
stock datsun b110
418 body length / 631 Extended / 462 Collapsed
Stroke: 169mm (6.7 in)
AE86
Body length: 402mm
Extended length: 604mm
Extended minus Body: 202mm
Outside Diameter: 43.5mm
so these should swap, be shorter and have more travel right??
thanks
