Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#7
Re: t25 turbo info needed
supafatto
Posted on: 2010/7/29 13:57
i have the lines fitted to the turbo but not to a series as a series is bsp and the braided lines i have are metris
#6
PIGDOG
Posted on: 2010/7/29 13:54
CA have the same thread in the block line i said, and they have an L shaped adaptor that the solid line screws into...kinda like a large brake line fitting
you have plenty of CAs, have a look at them
#5
supafatto
Posted on: 2010/7/29 13:19
need help on how people have setup oil and water lines and some pics as the a14 is bsp tread and the t25 is metric i think
#2
short-coupe
Posted on: 2010/7/28 11:40
yes mate, undo the four bolts that bolt the centre onto the ex housing and rotate 90 degrees, i would remove the actuator and undo the circlip and then rotate comp housing to suit the actuator or your piping, you wont need to rebuild it, seals are in the centre housing.
#1
t25 turbo water/oil line setup info needed
supafatto
Posted on: 2010/7/28 9:47
i neeed to know how to go about turning the oil line down on my t25.
ie do i unbolt the 4 bolts to the cast housing and undo the c clip on the turbo and turn?? will i need to rebuild it if i do this or can someone help out with info on how to do it. i need the oil return to face down as u will be able to see in the pic its not down. thanks nick Attach file: Image001.jpg (118.04 KB)![]() You can view topic.
