#11 Re: SR20 Questions!!!
noteven Posted on: 2010/11/7 11:28
just shows , dont have to have a long neck to be a goose.
s15 radiator i bought fits perfectly, after i stressed out about a radiator for mon ths hahaha idiot!.
had to get a pulsar water outlet and cut it and tig it making a bend to get my rad hoses in tho.
but all good and happy.
both fuel pumps mounted in happy days and surge tank hidden away in the boot.
another head scratching session trying to remember where all the hoses went on engine. before remmebering had to add 2 to the air intake.
cheers for info on speed sensor ill look into it.
#10 Re: SR20 Questions!!!
PIGDOG Posted on: 2010/11/5 2:46
should be able to just put an L series 71a b or c mechanical speedo sender in the gearbox then use a 120y speedo cable. then you will just have to get it calibrated so that it suits your setup (diff gears and tire size)
there is 2 different mechanical speedo sensors that the L series use. both will go in the gearbox but one has lessteeth than the other. so speedo will read differently depending on which one you get
#9 Re: SR20 Questions!!!
noteven Posted on: 2010/11/5 1:41
Oh really , I thought they were to big
Are we talking s13 ca18 or sr20 radiator ?
And hose outlets. Did you have to 90 deg bend it straight off the side of the motor ?
If it's easy fit between the rails I'll get one this afternoon :)
#8 Re: SR20 Questions!!!
perthute Posted on: 2010/11/4 23:01
i ran the s13 rad and the stock s13 clutch fan
rocker cover hose's ? u mean the oil breather's ? smash em all in a catch can or do it stock way one is a return, the other goes in between trubo and afm
#7 Re: SR20 Questions!!!
Posted on: 2010/11/4 22:47
um im using a s13 stock radiator to cool my L16, and mounted a fan on the front of it. Its only a 10inch fan and would be loking to fit a 12inch before summer if $$$ permit.
But this also means rulling the rad out agin and more angle grinding to fit the 12 inch fan.
#6 Re: SR20 Questions!!!
noteven Posted on: 2010/11/4 22:30
Sweet as boys :), one big weekend it is. Umm isn't s13 radiator too big to fit :s otherwise I would of bought one haha.
And the rocker cover hoses that come out, what config do they go haha. I forgot to take note when pulling them off.
And as far as thermo fans go? Anyone mounted them up front as I have minimal gap :(.
#5 Re: SR20 Questions!!!
perthute Posted on: 2010/11/4 22:04
will motor run without pollution gear ?
yep runs fine, red top, black top and vct models all run fine without ;)
#4 Re: SR20 Questions!!!
Posted on: 2010/11/4 14:10
try these guys they might know someone if they cant do it.
Sr20 radiator will fit same as s13 ca one, core is same, just top tank is different location.
if motor is tuned, it should run without polution gear, but if you are using stock computer, it might have sensors on some of the pollution stuff.
But you can do rad and fuel pump and battery easy as. speedo should be doable.
#3 Re: SR20 Questions!!!
old_school Posted on: 2010/11/4 13:45
Speedo: After market VDO speedo. This will run on any type of electronic speedo sensor. Including the stock nissan speedo sensor.
Alternativly the CA18 speedo cable setup Maddat sells coule be used with the stock 1200 speedo? Assume this would fit the later model SR box.
#2 Re: SR20 Questions!!!
WARDY Posted on: 2010/11/4 12:44
1. some people say that the stock feed line is good enough to use as the return, but i replaced both my feed and return with 5/16 steel pipe
2. Im also wondering about this! lol
3. Im running a CA but i used a alloy S13 radiator, fits perfectly in between the rails, and good bonnet clearance
4. Yes it will but wont pass engineering without them.
hope they help a bit
Wardy
