Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#8
Re: wanted: rear anti sway bar for 1200 ute.
vixen
Posted on: 2010/11/13 22:00
No pics The rear bar is 18mm and is mounted to the diff housing with U bolts and plates the ends are mounted to the floor near the chassis using long threade rods with rubber bushes so it can be adjusted.The bar is a bit large(a lot of oversteer) but its better than understeer and lifting rear wheels.The coupe only needs some small adjustments to the rear track and i think it will be fairly well balanced.
You could go to King springs and get a length of round spring steel and bend your own bar the take it back to them to be re heat treated about 70-80$.I would love to help you make one but your to far away.GREG
#7
ANGE
Posted on: 2010/11/13 3:23
thanks for the heads up, have you got any pics of your rear bar setup?
#6
perthute
Posted on: 2010/11/13 0:39
i got pedders to supply n fit a sway bar for my 1200 ute ,
befor sway bar i would lift a rear in corners and due to no lsd diff it would spin spin spin , after sway bar i rarely could get a rear to lift hope that helps you have some feed back befor buying :D
#5
ANGE
Posted on: 2010/11/12 21:55
thanks for this info guys, will give pedders a call
do you know what model gemini greg? also how thick is it? might take you up on your offer for a trial mik cheers guys
#4
Posted on: 2010/11/11 10:20
you could just try mine- not like its doing much here either.
#3
vixen
Posted on: 2010/11/11 8:22
Early Gemini rear sway bars fit with very little mods.GREG
I run one on my 120y coupe.
#2
supafatto
Posted on: 2010/11/11 7:55
pedders sell an off the shelf thing for a sedan wouldnt they almost be the same??
if so speak to lags his mate has one in his ca18 race sedan
#1
ANGE
Posted on: 2010/11/11 7:28
hi guys,
im chasing a rear anti sway bar to suit a 1200 ute. i have heard conflicting reports about them but i'd just like to try for myself. anyone got one? or know where to get? or a suitable donor vehicle to adapt? thanks in advance Andrew You can view topic.
