Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#2
Re: B310 with A15 charging issues.
bakat
Posted on: 2011/1/12 10:15
do the car still use the external voltage regulator? if so, you need to bypass the regulator, only if you installed 'new' type alternator.
#1
Squids
Posted on: 2011/1/12 8:53
Hi all, bit new to the datsun scene here in canada. I have a 1981 B310 with a swaped out A15. Fresh alternator and battery. The amp light on the dash stays on while car is running. When i disconnect the positive lead from battery the car dies. Had new alternator tested at the shop its all good. Checked the voltage regulator points on the back of the new alternator and they are good, all other wiring seems to be sweet. if you guys know of any thing i should be looking for please let me know!!! (and any ideas as to whats going on here with this jump wire thingy????)
Cheers thanks for your time all. squids You can view topic.
