(1) 2 3 »
#22 Re: aidaniels (no longer) supercharged 1200 ute
aidaniel Posted on: 2013/10/16 1:09
well im 5'6" so short enough haha
#21 Re: aidaniels (no longer) supercharged 1200 ute
Stock1200Ute1 Posted on: 2013/10/15 21:26
Looks good, I look forward to seeing this in action!
I hope you're 3 feet tall to be able to fit into a caged ute with buckets lmao
#20 Re: aidaniels (no longer) supercharged 1200 ute
aidaniel Posted on: 2013/10/15 13:17
got a little more done to the back ... ive got some ideas for the front setup but we will see how that pans out
#19 Re: aidaniels (no longer) supercharged 1200 ute
aidaniel Posted on: 2013/10/3 14:32
yea stu gives the best gobbies haha
#18 Re: aidaniels (no longer) supercharged 1200 ute
clyons8 Posted on: 2013/10/3 14:22
Is this your new found motivation after rubbing knobs with Stu?
#17 Re: aidaniels (no longer) supercharged 1200 ute
aidaniel Posted on: 2013/10/2 14:45
it needs like 200mm off both sides haha
#16 Re: aidaniels (no longer) supercharged 1200 ute
Posted on: 2013/10/2 10:30
Why shorten it? Would be heaps better to widen track all around
#15 Re: aidaniels (no longer) supercharged 1200 ute
lamb_daiquiri Posted on: 2013/10/2 10:21
Megasquirt works with EDIS and has instructions on how to make them talk. Although, MSII will run two coils for wasted spark directly. You could probably reflash a second hand delco unit as well. Have a look at http://pcmhacking.net/forums/. I may consider that route next time.
#14 Re: aidaniels supercharged 1200 ute *take 2*
aidaniel Posted on: 2013/10/2 2:42
out with the old rusty crap
new chassis
R31 diff im gonna cut down to fit
#13 Re: aidaniels supercharged 1200 ute *take 2*
aidaniel Posted on: 2013/10/2 2:37
haha well as always its been a long time between efforts put into the ute but have a new plan and new found motivation ... im going SR 4 link rear end custom front end and full cage. plan is to do hill climbs, bit of circuit and maybe some drag passes
(1) 2 3 »
