#2 Re: wiring for ecu -- help
bailz Posted on: 2011/3/18 23:55
U should have a throttle position sensor... As for the wiring it will be like a potentiometer. So as u open then throttle the ohms reading will
Change between the set values so the ecu can whether the throttle is at idle or a full
Noise.
Get a wiring diagram... Even the best auto sparks need a diagram....
#1 wiring for ecu -- help
nismo1 Posted on: 2011/3/18 18:44
hi what i need now is the help of the biker boys or auto elec boffins.throttle bodies are mounted & now i need to how to do wiring.this is what i got--- 38mm kawa throttle bodies oval one side[int] round[mani] side.one plug with 4pins and one plug with 3 pins which i think is sensor.how do i know what each pin is for.Is it 1 for each cyl etc. checked kawa zx6r diagrams but not getting download
