#7 Re: offset to suit?
1200rallycar Posted on: 2011/5/21 14:08
i love this calculator to compare wheel offsets, but you need to know something that sort of fits to compare to
calculator
i personally think 6 inch wide is max wheel width on front, but thats with a 195 tyre and lipped guards etc. if you muck around with stretch that changes things
#6 Re: offset to suit?
iDatto Posted on: 2011/5/21 13:45
i found some tyres, i think 175 55 14 for like 120 each, seem to be pretty good aswell, i think ill do that!
#5 Re: offset to suit?
Posted on: 2011/5/17 1:52
oh you can also find 165 65 and 175 60 14 easily enough too.
#4 Re: offset to suit?
depends how low you go on the rear with tire profiles, but a 175 65 14 will stretch nicely on the 7 inch rim, and then probably clear the rear step on a sedan.
should sit nicely too.
#3 Re: offset to suit?
iDatto Posted on: 2011/5/16 10:52
you recon flush or?
#2 Re: offset to suit?
DA75EZ Posted on: 2011/5/16 10:29
Yes they will fit dude no probs
#1 offset to suit?
iDatto Posted on: 2011/5/16 10:25
14x7 +2, 14x6.5 +9
will these offset wheels suit my sedan?
im still not to sure on what offsets will fit under the gaurds of the sedan..
thanks for the help, also if you could post up the offsets of wheels that you have fitted to your 1200s?
also, im running 120y suspension
