#5 Re: turbo selection
mcdat Posted on: 2011/5/17 10:17
I think i will leave it up to the guy that is doing the actual conversions for me ill tell him that i want a billit turbo and leave it up to him
#4 Re: turbo selection
oda70 Posted on: 2011/5/17 10:01
whos going to rebuild your motor? lewis. The inlet manifold has alot of stuff on it that needs to be checked, aswell as vac/water lines.
#3 Re: turbo selection
mcdat Posted on: 2011/5/17 9:45
Hi Oda70 i am not putting a garrett turbo on i am buying a billit turbo from http://www.turbocreations.com/fj20/fa ... ils.html#nissan%20ca18det
#2 Re: turbo selection
oda70 Posted on: 2011/5/17 9:27
mc dat, the gt28rs garrett turbo will get you 200kw at about 18psi from what ive read, gt2871 about 250kw with cams.
#1 turbo selection
mcdat Posted on: 2011/5/17 8:50
Hi everyone i need help rebuilding a ca18 with all the goodies(spool stroker crank,cp pistons xcetra) would like 300hp straight of the top if i put a turbo rated at 300-480hp and it works out that i have less than 300hp with the rebuild will there be and problems and what will be the problems be.Like i said i would like 300hp off the top then build apon that,thats why i am selecting a 300-480hp turbo is this the way to go about things
