#7 Re: Maddat fuel cell
PIGDOG Posted on: 2011/5/24 0:25
do CAs really need forged cranks?
anyway, the fuel tank wont change the power that the car can make. all you would want to do is add some baffles to the tank or run a surge tank so that you always have fuel at the pump
#6 Re: Maddat fuel cell
perthute Posted on: 2011/5/23 22:30
maddat sell a fuel cell ?
#5 Re: Maddat fuel cell
srb210 Posted on: 2011/5/23 14:26
Probably not just down to cell or tank. Look at starting at fuel rail and work back in my opinion. You will need to efi convert a tank either way. Fuel cells will run a bladder or foam instead of baffles. Other question is you wanting this adr'd?
Good rule I've heard-
budget build- spend if you have to
Glory build - spend It cause you want to
#4 Re: Maddat fuel cell
SXC-DTO Posted on: 2011/5/23 12:24
Well I have a 1200 ute with a ca18det in it n I'm putting forged crank n pistons in n bigger turbo different inlet manifold so I dono if I need it or don't worry
#3 Re: Maddat fuel cell
clyons8 Posted on: 2011/5/23 12:24
Is it a race car SXC DaTO?
#2 Re: Maddat fuel cell
PIGDOG Posted on: 2011/5/23 12:21
do you really need a fuel cell?
the fuel tank(stock) in my car did a perfectly good job of holding onto my fuel
#1 Maddat fuel cell
SXC-DTO Posted on: 2011/5/23 11:39
Is a mad dat fuel cell really worth it
