#3 Re: anyone know about this quad setup?
revhead001 Posted on: 2011/7/3 1:40
Tommo bought a twin weber manifold cheap off ebay for around the $250 mark. I don't see change from $1K for a billet manifold. Most likely more. The billet is the cheap part. It's all the run time that's expensive.
#2 Re: anyone know about this quad setup?
ddgonzal Posted on: 2011/7/2 18:44
Yep, makes the CA sounds like a real engine. Then you can throw away the cam angle sensors and ECU and just run a crank trigger ignition. Keep it simple.
#1 anyone know about this quad setup?
D Posted on: 2011/7/2 16:44
