#7 Re: Engine build - Oil gallery
LOWTECH Posted on: 2011/9/19 9:00
I drilled and tapped mine last week for 9/16-18 countersunk threaded plugs.
#6 Re: Engine build - Oil gallery
DISCO_BOB Posted on: 2011/9/16 11:47
parts book is at work, i can let you know monday.
some one on here must have a number.
l series ones are similar (i think).
#5 Re: Engine build - Oil gallery
fredeuce Posted on: 2011/9/16 8:02
Disco-bob,
Thanks for your input .
Do you have a part no. for these bungs?
I have access to a lathe so I might just turn up some new ones in brass.
Don't worry about the beer , there is a carton already organised!
#4 Re: Engine build - Oil gallery
DISCO_BOB Posted on: 2011/9/16 7:49
drill a holes in bungs. screw then slide hammer out. clean block properly.
get new bungs from nissan(they only sell them in lots of 5). hammer in new bungs.
have a beer. look at how mighty the a series motor is. have another beer.
#3 Re: Engine build - Oil gallery
ssskiwi Posted on: 2011/9/16 4:14
I would think they need to be cleaned properly but not sure on the drilling of the plugs.
Would assume that you could just drill and tap to refit threaded plugs?
#2 Re: Engine build - Oil gallery
fredeuce Posted on: 2011/9/16 3:56
bttt.
Anybody have a view on this?
#1 Engine build - Oil gallery
fredeuce Posted on: 2011/9/13 13:02
I am in the process of building up a fresh 1200 . I am curious to know if the oil gallery in the block can be adequately cleaned without removing the two gallery plugs?
If not, it appears they need to be drilled out. Anyone done this before?
