Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#12
Re: EOI A series steampipe turbo manifold
reuby_tuesday
Posted on: 2011/9/15 12:35
looking at that again, it might even fit into a thou since the turbo sits high enough...
#11
lethal_john
Posted on: 2011/9/15 11:59
certainly is well made! you should get good money for it
#10
DISCO_BOB
Posted on: 2011/9/15 11:01
its a proper laser cut merge collector will take a photo down the outlet tomorrow.
the inlet manifold isn't finished yet(still waiting on parts) -using a cylon(chris)oval port(can use round haven't stated yet) flange. 32mm id alloy tube(still trying to get bends)that goes over the rocker cover to the other side into a oem plenumn using a GM throttlebody (50mm?)(can't remember). the idea was to keep runners skinny(not to skinny), IC pipe to match throttle opening, have the only step in pipe ID from turbo outlet, to minimise lag(for want of a better term (pressure drop?)) anyway EX manifold is fully TIG welded, all arms were welded off the manifold too minimise stress on joints, all tacked up,then welded onto merge collector, then removed from head flange, arms made even(flat)then welded(bolted tight to head)to flange. has been painted with heat paint. the 2 bolt holes were on the T25flange, you could run a brace off it but i think i could stand on it (steam pipe is strong).
#8
clyons8
Posted on: 2011/9/15 9:13
Yeah there are several options you could take. I just wanted to know what the fabricator had in mind, if he fabricates something that neat he obviously had something good planned for the delivery, that's what I'd like to hear more about(and of course, how much/price).
#6
reuby_tuesday
Posted on: 2011/9/15 9:00
you could wrap the intake over the head and onto the other side. Would give long intake runners and fee up some space, and make fitting an intercooler eaiser.
#5
clyons8
Posted on: 2011/9/15 8:55
Would be interested to hear what you were planning for a inlet plenum or manifold? It looks very tight in there, or was the inlet manifold going to straddle the turbo manifold (with the plenum snug up against the strut tower- under the turbo)? Nice design for cross flow heads & beautifully made.
I've sent you a PM. Chris You can view topic.
