#3 Re: Comprestion Test
davem69 Posted on: 2011/12/9 0:40
Well what i was try say was my mechanic has a tool and i got a manul as well.
But this close to xmas he is realy bussy i was hopeing to offer to buy some body lunch or a sixpac. And go over to thear place and maby even give a bit of a turn as well?
#2 Re: Comprestion Test
reuby_tuesday Posted on: 2011/12/8 22:48
Compression testing is pretty easy.
You just need a compression guage, and someone to crank the engine for you. (Hec a screwdriver accross the starter will do in a pinch). Read the numbers and test done. You will spend longer getting the plugs out and back in then doing the test.
If you dont understand the numbers you get, post them up, and a guru here will give you some advice. If you have a low piston, it will be obvious.
#1 Comprestion Test
davem69 Posted on: 2011/12/8 14:00
Brisbane guys i need a help to do a Compression test on My B310
sunny i have a A14 in it and it has a drity plug problem and use,s
a bit of oil and blow,s white smoke as a result
