Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#8
Re: alloy oil pan
mcdat
Posted on: 2013/7/30 6:56
Hi guys whats the advantage off this style off sump?
#7
Re: alloy oil pan
Posted on: 2013/7/30 5:44
The real level of oil won't change. The dipstick measures the correct level relatively to the crankshaft, so it is independent oil oil sump shape.
#6
Re: alloy oil pan
Curlys
Posted on: 2013/7/30 3:49
I have one of these alloy oil pan, if i decide to modify the bottom... what is the real level of oil ?
#5
Re: alloy oil pan
LittleFireyOne
Posted on: 2011/12/15 6:40
You've never seen a wombat angry until you've gone and started chopping up his alloy, they use that stuff in the burrows you know
#3
Re: alloy oil pan
Posted on: 2011/12/15 4:09
The oil capacity depends on how big a a sump you weld to the alloy pan.
The Datsun Cherry 1971-1975 has an alloy pan. Cut off the superdeep sump and weld on your choice of sump-box to make a wider, shallower sump.
#2
Re: alloy oil pan
Rallytwit
Posted on: 2011/12/15 2:36
Dave I have an extra dry sump pan that I contemplated doing that with...........how much does that increase the oil capacity?
Tom
#1
alloy oil pan
Posted on: 2011/12/15 2:25
