Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#16
Re: Custom Made Head Gasket A15 stroked.
Posted on: 2012/1/9 17:41
found myself hitting 10 000+ rpm's which i would say contributed to me blowing my head gasket That won't cause a head gasket problem. More likely to break a piston or bend a valve, but the A-series is tough. Head gasket problems are almost always caused by these: * Overheating * wrong torque (fasten in three stages, circular pattern) * incorrect prep. Block and head face impeccably clean, threads chased, not oiled Less likely causes for a blown head gasket are: * Defect in manufacture of gasket * head warped past spec (4 thousands inch) * Extrememly high combustion pressure (more than 10 pounds boost?) * Bored in excess of 79 mm (may need fire rings) Quote: the piston holes in it are 79mm could be 80mm but wouldnt trust a ruler A ruler can measure to an accuracy of 1mm. A15 with 79mm pistons: 1608cc A15 with 80mm pistons: 1649cc
#15
Dion120Y
Posted on: 2012/1/9 7:21
yeah i would really hope for 10 000 but obviously wont get that, the engine is capable of 8500rpm but i pulled a massive burnout at my farm and found myself hitting 10 000+ rpm's which i would say contributed to me blowing my head gasket, will the nismo gasket hold 8500 easy?
#14
Dion120Y
Posted on: 2012/1/9 7:13
tryed to measure the gasket today with a ruler, (almost 100% its not accurate) but it seems the piston holes in it are 79mm could be 80mm but wouldnt trust a ruler, i need one of those proper digital measuring thingo's.
#13
LAGWAGON
Posted on: 2012/1/9 2:52
huh? you have a warped head gasket?... a atandard gasket will allow a mild overbore. why are you boring it so big? be a bit careful, if you are mixing up bore with stroke and getting told a copper head gasket is the go you might need to understand a bit more before your budget gets blown!
speak to ernie (bige) he is an a series guru and will point you in the right direction
#12
Lemonhead
Posted on: 2012/1/8 21:54
I'm with bige - good luck with 10,000rpm...
From my experience, it is far easier to bore a big bore block to suit a big bore head gasket than it is to get a big bore head gasket made (and work) to suit a big bore block. Words of advice for anybody wanting to do big bore stuff in the future, start with the head gasket.
#11
bige
Posted on: 2012/1/8 21:10
good luck with 1o,ooorpm ,with 80mm bore (what pistons & rods), call me if help needed. nimso make a multi shim 80.5mm head gasket.(copper will need o-ringing)
#10
Dion120Y
Posted on: 2012/1/8 13:59
Decided to head down to Obriens Aluminum in Windsor, using my warped head gasket get them to make me one out of copper, my mechanic suggests that its my best bet as only the 2 centre holes in the gasket are warped and the outer 2 are just fine.Cheers guys!
Dion
#9
Dion120Y
Posted on: 2012/1/7 7:15
ahh ok, thanks for that :) when it comes to stroke and all this i am just so confused, ill definitely give it a look, and bige what do you recommend, i want it to handle 10 0000 preferably .
#8
Posted on: 2012/1/7 6:50
Stock A15 stroke with 80mm pistons is 1649cc. The Nismo gasket handles high RPMs no problem (8500 rpm).
The Nismo gasket is 79mm Bprojects Australia sells a 80.5 gasket. You might ask Bige what he recommends.
#7
Dion120Y
Posted on: 2012/1/7 5:08
its been bored out to 1650cc, so will they fit? an di need to hold as much rpm as possible
