#10 Re: supercharer
spirax999 Posted on: 2012/1/16 11:41
thanks for the info looking for around 12 to 14 psi going to tuck blow off on inlet somewhere outa sight where do i find these crank pulleys
#9 Re: supercharer
randoli Posted on: 2012/1/14 8:00
yep - mines running the os crank pulley @11psi
#8 Re: supercharer
hcope86 Posted on: 2012/1/13 2:43
Due to the electric clutch making it fairly hard to swap out the pulley on the charger, its much more common for 4AGZE owners to swap the crank pulley for a larger diameter one, which has the same effect as putting a smaller one on the charger. I used to have a GZE in my corolla, and back in those days the 175mm crank pulley made by Nevo was all the rage, the kit was pretty cheap too.
Its a complete replacement pulley, but only the splines for the charger belt are oversized.
From a 175mm crank pulley, you can expect about 14~ psi of boost, which is what most people Ive known run. Makes a fair bit of difference!
HTH
#7 Re: supercharer
DatsAmore Posted on: 2012/1/13 1:36
Great motor and awesome little s/c as well. I love how the clutch for the blower pulley is electric - means that a switch can be added to the circuit... Perfect to watch Commodore driver's jaws drop as you flick it and wave as you sail past lol
#6 Re: supercharer
randoli Posted on: 2012/1/12 22:57
hi, just read youre running a 4A - so am i. always keen to see some photos and share some info. where are you at? i'm in brissy. pm me with some pics and any other info you care to share. check out my pics in my album - just click on my user name to access my profile. cheers
#5 Re: supercharer
spirax999 Posted on: 2012/1/8 3:53
ill look them up thanks
#4 Re: supercharer
JsGarage Posted on: 2012/1/8 2:32
TRD make a smaller pulley for that.
#3 Re: supercharer
spirax999 Posted on: 2012/1/8 2:04
SORRY MISSED SOME IMPORTANT IFFO HEY
4agze out of a sprinter now sitting proudly in the little 1200
#2 Re: supercharer
dattoman_1000 Posted on: 2012/1/8 1:57
For what sort of supercharger ?
#1 supercharer
spirax999 Posted on: 2012/1/8 1:36
just wondering who are the go to people for supercharger pulleys in australia looking for smaller clutched pulley bump it a couple more psi
