Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#7
Re: Tomei RACING CAMSHAFT
loosekid
Posted on: 2012/5/8 5:14
Im looking to get 100-120 hp if its possible im not sure if it will be or not with out a turbo setup. But Atm i have 45mm webers with 4 into 1 extractors so with new head, CAM and CAM Gears and what not should give it a fair boost, unsure how much tho. So im not sure if i could get an extra 40 hp from the standard 80hp (60kw)id be more then happy with a 20hp increase. I have mates wanting me to do a CA18DE conversion as you can pick up a half cut for around $1500.00 but im against it as it means alot of extra work and changing x-members and many other things what i really want is to keep the car as much to its originality as posible and the A15 series engines does exactly that give me the little extra power i want for a cruiser and the originality of the car itself
#6
Stock1200Ute1
Posted on: 2012/5/8 4:03
I also have a camshaft pretty chunky it's a wade 240 receive. Pm me if you're interested. You would need to have your lifter refaced also...
#5
bige
Posted on: 2012/5/8 3:32
the std conrods will handle must performance engines, i've ran them in many full on race engines, but also you can get your std conrods,crack tested, polished & shot peened and rod bolted & balanced for that reassurance you may like.
what are your engine specs/components your building. maybe i can help with combo if your interested.cheers
#4
loosekid
Posted on: 2012/5/8 2:22
Well thats great to know cause i have not ordered anything as of yet. So im certainly keen to purchase some goods from you :)
But still in regards to the Conrods will they be all good standard or will i need to change them with the Cam you have
#3
bige
Posted on: 2012/5/8 2:01
i can supply cam & chain at a lot better price then that, similar specs on cam.
and what about lifters for cam.cheers in stock ready to post(cam/lifters/chain)& timing gears (std type)& much more.
#1
loosekid
Posted on: 2012/5/8 1:56
Just a quick Question for you boys
Im looking to change the CAMSHAFT in my A15 to either. RACING CAMSHAFT 312-7.5, DATSUN 1200 A15 http://www.ebay.com.au/itm/RACING-CAM ... ories&hash=item3cc39e1a2b Or to the smaller Tomei Procam Nissan A12/A14/A15 304-7.25mm http://www.ebay.com.au/itm/Tomei-Proc ... ories&hash=item4d0085956e Now My main question is with my internals currently i have not changed the Conrods or pistons is it possible to run either of these CAM's with out changing the conrods? Or if needing to change the conrods what is the best option to change them to?? ---------------------------------------- Currently i am changing out the Head for a new oval port A15 Head An Adjustable CAM Gear http://www.ebay.com.au/itm/Racing-Tim ... ories&hash=item56471abe27 with a new Timing chain http://www.ebay.com.au/itm/RACING-Hea ... ories&hash=item56458bfb7a And a new Fly wheel The only thing im not changing is the ConRods and piston setup but wanting a new CAM to get things going a bit more any help would be nice. Also is anyone running one of these Tomei Camshafts? You can view topic.
