#2 Re: 120y x member conversion etc...
ddgonzal Posted on: 2012/6/15 6:47
Will the Y steering arm fit the 180B ball joint?
I doubt it.
Why do you want to use the 180B LCAs and caster rods? I think the 120Y LCAs will bolt up to the 180B x-member. The LCAs look quite different but still bolt up if i remember correctly.
#1 120y x member conversion etc...
bluematter87 Posted on: 2012/6/15 3:51
Gday,
I'm planning to put an L18 and bluey 5 speed that I've got into my 120y wagon I've nutted most of it out but i have a question-
If i use a 180B x member, LCA's, castor rods etc. Can i still use 120y steering arms and struts? Will the Y steering arm fit the 180B ball joint? My y struts will be fitted with S13 brakes shortly and I'd like to continue using them after the conversion. Any advice would be much appreciated.
Cheers
Zak.
