Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#11
Re: ute weight in standard form
ANGE
Posted on: 2012/6/27 11:45
my ute was weighed pre-conversion, so it was still running an a12 & 4speed with h165 diff.
but it did have heavier stanza front struts/brakes and 15x6 skyline wheels to give an indication
#10
mcdat
Posted on: 2012/6/27 9:46
My rego papers say tare weight is 680kg.
#9
Lachie
Posted on: 2012/6/27 9:07
On my rego papers it has the tare weight at 690kg. When I did my conversion the ACT rego people said that they take the weight of the heaviest model in the range which is the wagon at 720kg (720 x 2.5 = 1800). just ring the rta, it'll save a heap of rumors.
#8
greendog
Posted on: 2012/6/27 9:06
me nsw rego paper say 720 im 99% sure
edit:no i was wrong rego paper says tare 690kg gvm 1380.. 85 ute
#7
Posted on: 2012/6/27 9:05
It's not official at all. It's what Ange measured for his ute.
The "official" measurement that the state cares about is usually either the published tare weight or the Engineer's measurement.
#6
bailz
Posted on: 2012/6/27 9:03
with utes in WA i am sure the regs are the heaviest vehicle of that model... being the coupe... so ca18det scrapes in
#5
demacoz
Posted on: 2012/6/27 8:53
If 730Kg for a ute is the official original kerb side weight then at the regulations (times 2.5) a CA18DET at 1809cc would just fit into the guidelines.
How official is 730Kg's ?? - what does the roads authority say ?
#4
Posted on: 2012/6/27 8:05
Ange had his weighed pre-conversion. It was 730kg.
Ute: 730kg (one example measured) Coupe is 750kg (manual) Sedans are 696-741 kg It all depends on how much fuel, and if using stock components. Plus options like carpet, tranmission type, etc.
#2
Posted on: 2012/6/27 7:53
whats the exact height off a ute That's the nominal/official height with the stock 12" tires. You can view topic.
