Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#14
Re: Electrical Issues
ayden_d
Posted on: 2012/8/10 4:00
Turned out it was the alternator, the rotor was busted.
Thanks for your help mate!
#12
ayden_d
Posted on: 2012/8/8 9:46
Oh I see, alright just checked it and it says 0.38 so that means a different issue?
#11
Posted on: 2012/8/8 9:27
Forget the A & E wires.
Pull the T-connector out and measure the voltage in the two wires that end in the Tee. Put voltmeter black wire on negative battery post. Put red wire in T-connector. One of the wires should have 12V. If not, you have a wiring problem.
#10
ayden_d
Posted on: 2012/8/8 9:04
Sorry A and E is where to 2 wires connect. Even when I pulled the T connector out of the alternator I still got 12V so does this mean that it is not the alternator but a fuse?
Or as the alternator is internally regulated, if that's faulty I'll have to get the alternator repaired hey?
#9
Posted on: 2012/8/8 8:53
A & E?
Pull the T-connector out of the alternator. Check for 12V in the two wires that attach to the connector. See Alternator diagnoses for a boatload of tests. Or just replace the alternator, and if it's not that, then buy a new regulator and if that doesn't fix it, take it to a sparky.
#8
ayden_d
Also its an 84 model so it is internally regulated
#7
ayden_d
Posted on: 2012/8/8 8:50
Oh right, sorry bit confused but do you mean put the voltmeter on the A and E on the alternator? If thats the case then yes I still get 12V
#6
Posted on: 2012/8/8 8:19
WAIT - no output at the alternator does not mean the alternator is bad. Test it. Do you get 12V at the T-connector? If not, that's a different problem. Could be as simple as the Regulator fuse needs replacement.
#5
ayden_d
Posted on: 2012/8/8 7:45
Looked through the receipt and I got it wrong he replaced the starter not the alternator.
Just checked with a multimeter and there is no change from the motor on or off so must be a shot alternator. Sorry for making a new thread thought there was a connection with all the other things! Anyone got a spare alternator?? You can view topic.
