#5 Re: Valve spring question
mrsprite Posted on: 2012/8/20 7:40
Thanks Tom......I'll give the machine shop these numbers and we'll see what happens.
#4 Re: Valve spring question
Rallytwit Posted on: 2012/8/20 1:42
When the machine shop installs the new valve seats for the intakes, they may or may not be at the same height.
My manual says 1.516 loaded with 1.7992 free length.
The Isky dual valve springs I have call for a 1.51 installed height and the Nissan competition were 1.61 installed height.
Tom
#3 Re: Valve spring question
mrsprite Posted on: 2012/8/18 15:00
Thanks for the reply. To clarify.....I'm running a stock cam and slightly dished pistons, so that shouldn't be an issue. I currently have 30mm & 35mm valves......the new ones are 30mm & 37mm, so the intakes are going to be slightly bigger. I think that is why the shop was asking the questions. So......what should the installed height be so we can measure it? Is there a factory spec and what is it?
I appreciate it......I want this to go back together correctly! :)
#2 Re: Valve spring question
jmac Posted on: 2012/8/18 7:27
The valves will be slightly cloer to the block and pistons, but their height 'within' the head won't be affected by the surface grind of the head. You will need to re-set the tappet clearances since the head has 'effectively' moved closer to the block. It will affect rocker geometry to some small extent, but nothing to worry about unless you were taking off major amounts of material (which I gather i not the case).
If you were hypothetically running a really serious cam, then you might want to put clay on the piston crowns, and re-fit the head with a dummy head gasket, or washers the same thickness as the compressed head gasket, and turn the motor over (by hand) and see just how close it currently comes to piston to valve contact (and the 'risk' areas are usually around or between 10 degrees either side of top dead centre, as the exhaust is still closing as the piston heads for tdc, then the intake valve is opening as the piston still travels up but then opens more and more as the piston starts travelling downward. And so forth.
If it is currently _very_ close to making contact, you have to work out whether or not a surface skim might put you into a danger area. There's some debate as far as to how close is safe or not (remember you are checking at room temp) - but if there is something like 100 thou, you'll be nowhere near danger with a minimal head skim just to clean it up.
If it is getting too close for comfort, then you'd need to enlarge (or create) valve reliefs on the piston crown.
It's all a bit of an unknown without knowing how severe the cam timing/lift is, and the piston crown shapes etc.
I just re-read it and you mention fitting new valves. Sight unseen (by me at least) I'm assuming they might be slightly larger diameter than the previous ones? In which case you'll haqve to check clearances even if you didn't skim the head surface. It's also possible the new valves will sit 'lower' in the head, since they'll 'seat' at a different point than the previous smaller diameter ones will. If they sit lower in the head (when viewed as if the head was fitted, though most head porters talk about high and low with the head upside down as that's how they work on the seats, so to speak) then that would alter the valve spring height. It'd actually (if the collet grooves are in the same place on the old and new valves - and that isn't a certainty) increase valve spring pressure a little. If the valves sit higher in the head, it would reduce it.
So the short story of all that - if you are just skimming the head, no change to valve spring intalled height will occur, so no concerns. IF you are putting in new (esp slightly larger) valves, you are going to have to physically check for valve to piston clearance AND also valve spring installed height and shimming may or may not be required. No way anyone could answer that one with any certainty, we'd all have to measure it :)
#1 Valve spring question
mrsprite Posted on: 2012/8/18 2:29
I have an A15 with a GX/competition head in my '59 Austin Healey Sprite. It has had at least one valve job before and the head was resurfaced at that point and may be resurfaced again this time as well (if it needs it).
My question is this.....by milling the head do I need to shim the valve springs? What should the installed height be?
I am fitting new SI valves (30mm & 37mm) and I also have new GX springs, retainers, etc. that will be going on it and want to make sure everything works as it should when all is said & done.
Any help would be great. I've done a lot of searching here and on Google and can't seem to find what I am looking for. Sorry if this is a stupid question......the machine shop guy asked me and I had no idea what the answer was.
Thanks.
