Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#2
Re: 200B struts onto a 1200 ute
dattodude
Posted on: 2002/3/27 9:39
I've done it.
I'd recommend you use a little trial and error. Using the standard struts inserts, move the cup up by one inch higher than the point the cup would sit if you didn't load the unit at all. This pre-loads the spring, and stops them falling out under full 'droop'. Use only 2 'good' tacks with the mig, and trial fit it, preferably with the guards on and engine in. If it's too high, move the spring cup down the strut the amount required. The travel in shock absorber should be used to it's maximum. And the spring should be as loaded as it would be in the 1200 struts. Remember, you can get the springs made to suit the required height. I don't think I can tell you exactly, as my brother has my 200B/1200 struts. On his 1600 using the 1200 springs. You can try and guess the position from my online picture.. http://www.geocities.com/motorcity/2330/diff_str.jpg Good luck, if I get better measurements, I'll let you know. Chris
#1
lump_a_charcoal
Posted on: 2002/3/26 1:39
Who has done this conversion, using the 1200 springs? i need to know where to weld the lower stanza spring platform onto the 200B strut.
cheers, Linc. You can view topic.
