#8 Re: Electric Choke Help
RippDatsun Posted on: 2013/1/21 6:40
Fixed. The screw I adjusted before needed to be loosened even further as it was stopping the little arm that pushes from extending all the way
#7 Re: Electric Choke Help
RippDatsun Posted on: 2013/1/21 6:26
This joint seems to be the problem. As you can see it has about a 30 degree play in it
Any ideas on how to fix it?
#6 Re: Electric Choke Help
ddgonzal Posted on: 2013/1/21 6:11
Here's my Weber, an older model
#5 Re: Electric Choke Help
RippDatsun Posted on: 2013/1/21 5:48
Okay so I loosened this screw a few turns:
which allowed me to close it 100%
but as you can see in this second photo, it doesn't stay closed even though the little arm controlling it doesn't move
Whats up with that?
#4 Re: Electric Choke Help
RippDatsun Posted on: 2013/1/21 5:33
Thanks ddgonzal for fixing the pics. Just realised I tried linking the pics in album form rather than just the picture I wanted. My bad
#3 Re: Electric Choke Help
ddgonzal Posted on: 2013/1/21 5:26
But by moving part where the spring attaches to;
it only goes to here;
and here it is at open (engine warm)
top: Open in new window
side: Open in new window
There is quite some play in this part;
which allows me to close the choke all the way by hand even though the control arm for it doesn't move.
So my question is. Is something loose, broken or missing. Or is it meant to be how it is?
#2 Re: Electric Choke Help
ddgonzal Posted on: 2013/1/21 5:24
No, the choke should close 100%, not the 90% closed shown in this photo
So when cold and choke is fully on it should look like this, correct?
#1 Electric Choke Help
RippDatsun Posted on: 2013/1/21 5:13
Hey fellas. I decided to wire up my electric choke today (it was disconnected when I bought it).
Went down to Jaycar and got the required parts I needed. Found a switched 12v on the ignition harness and ran a wire through the hole where the manual choke goes.
I have a problem that I am not sure about and I will try and explain my best using pictures to help because I don't know the proper names for some things :p
imgur
But by moving part where the spring attaches to;imgur
it only goes to here;imgur
top: imgur
side: imgur
There is quite some play in this part; imgur
Advice much appreciated
Edit: Pics didn't work so I just added links sorry
