#22 Re: Cost of installing maddat tunnel?
wayne080866 Posted on: 2013/1/30 11:16
The last maddat tunnel I saw had no lip on it , it just had a raw edge so it would need to have the lip turned out on it to be able to have a 20mm overlap, I have cutout and repaced or widened alot of tunnels , it takes time to do it right and not look like #OOPS# so I think $800 is a bargan.. remember in most cases you get what you pay for.
#21 Re: Cost of installing maddat tunnel?
bailz Posted on: 2013/1/30 8:54
Thanks for the info guys I really appreciate it :) heaps of
Different options I would never of thought of ;)
#20 Re: Cost of installing maddat tunnel?
jmac Posted on: 2013/1/30 5:19
The last time I did something like this the 'standard' for engineering approval was the overlap as mentioned but then seam weld (complete all the way around) on one side, and then stitch weld (weld 1-2 inches, then a small gap then the next 'stitch' ) - the reasoning was that the seam weld would have the strength, but absolute worse case, if the stitch weld cracked, the crack could only travel the length of one stitch, not all the way around. If you do do it that way, do the seam on the underneath (even though it's harder to do) and the stitch on the top side, as it won't let water get in there (yes body sealer should stop that, but don't count on it 100%)
If the place you are taking it to are absolute top notch craftsmen, that's not an unfair price. I'll tell you one thing, take it somewhere 'cut price' and if they stuff it up, have fun trying to repair it and then put the tunnel insert section (possibly the second one if they stuff the original up enough!) in.
#19 Re: Cost of installing maddat tunnel?
bailz Posted on: 2013/1/30 2:33
Cut tunnel out, fully weld all round, make it fit perfect, seam seal both sides, prime and prep for paint. I am not worried about the cost just wanted to know whether anyone else had actually had a maddat installed professionally and not installed by yourself or a different tunnel installed
#18 Re: Cost of installing maddat tunnel?
shaun Posted on: 2013/1/30 2:16
I had a tunnel fully rolled up and welded in by a professional fabrication shop for 300, that was around 5 years ago though but I'd say around that maybe 400 to just weld one in
#17 Re: Cost of installing maddat tunnel?
edp Posted on: 2013/1/29 23:26
I dont know I'd have to be pretty convinced they were a decent welder to feel good about only being charged $100 to weld in a tunnel. Not that I'd be thrilled to pay more but a pro welding shop should charge around $75 - $90 & hour & there's no way you can do that complete in an hour. NOw $800 is a different story, I'd say between $225 & $350 is probably about right for pro job. That's a lot of spot or stitch welding to do.
#16 Re: Cost of installing maddat tunnel?
Posted on: 2013/1/29 20:37
Protons aren't made dd, they are a digestive systems by product from a really bad curry dinner
#15 Re: Cost of installing maddat tunnel?
ddgonzal Posted on: 2013/1/29 19:59
Is that true? Is a 2012 Kia or Proton made with fully welded and highly overlapping sections?
#14 Re: Cost of installing maddat tunnel?
crab45 Posted on: 2013/1/29 14:43
fiasss wrote:
I find it overkill that people expect the tunnel to be fully welded inside and out with a 20mm ovelap.
Has anyone ever had a look at the tunnel in a factory automatic 1200?
there is less than 20mm overlap and random spotwelds joining the enlarged tunnel section to the floor/firewall.
That tunnel is made to 40 year old standards.
2012/13 standards require 20mm overlap and fully welded.
#13 Re: Cost of installing maddat tunnel?
fiasss Posted on: 2013/1/29 13:31
(1) 2 3 »
