Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#10
Re: Making an inlet gasket for CA
bailz
Posted on: 2013/1/29 22:32
I might have a spare gasket laying around I can probably mcdat but I won't be home for 2 weeks if u can wait that long?
#9
estyre
Posted on: 2013/1/29 12:55
yea dattodude is right ,i did that on my a15 when i ported it ,just sit the gasket over the studs on the head then dremel the inside out to suit, easy ,cheap and wont leak like a home made gasket will
plus will look 10 times neater
#8
dattodude
Posted on: 2013/1/29 11:18
The surfaces are flat and even, they will only see 30 pound boost.
It's still not close to the head pressures of 200-300psi seen in the cylinder. Just buy a standard paper gasket, trim it to suit, and correctly torque everything.
#7
mcdat
Posted on: 2013/1/29 8:44
Hi dd its a det so im guessing that i need the metal one.
#6
Posted on: 2013/1/29 8:19
The one with metal is not needed for non-Turbo use.
Just use gasket material of the appropriate thickness.
#5
mcdat
Posted on: 2013/1/29 8:00
So guys do i need the gasket paper with the thin steel middle,what the plan is is to buy the normal gasket copy it onto the gasket paper,then do the mods,then cut it out.
#4
___1200ute
Posted on: 2013/1/29 7:13
I'd still use a standard one and just trim it back, atleast the bolt holes and the outside edges are already the right shape.
#3
mcdat
Posted on: 2013/1/29 6:52
Hi clyons im getting work done to the head,so the standard one wont be any good.Im getting the 8 port converted into 4 larger ports,like this.
#2
clyons8
Posted on: 2013/1/29 6:37
Is it better to buy one perhaps? Might save you alot of hassle?
#1
mcdat
Posted on: 2013/1/29 6:00
Hi guys just rang repco about some gasket paper.Apparently theres 2 different types,one normal and one with a thin sheet off metal in the centre.Which one do i need?
