#2 Re: A12 using A15 camshaft
ddgonzal Posted on: 2013/2/3 3:03
Depends on which A15 you have.
Some A15 use the same camshaft as A14 hi-po. This is typically a circa 1980 B310 engine.
Some A14/A15 use a medium cam (round port A14 engines)
Other A15s use a mild camshaft, less powerful than the A12 camshaft. Typically the oval port 1982 and up (or thereabouts).
#1 A12 using A15 camshaft
demontweaks Posted on: 2013/1/31 16:22
A12 or A14 engine if using or swap A15 camshaft, is there any different in power increase?? tq
