#2 Re: Celica 5 speed conversion
ca18det_man Posted on: 2002/7/5 12:24
Hi linc the dellow kit should have come with a clutch and brass bush for the new spigot hole. you will need to make a new hole as its around 70mm further back. crossmeber shoudl be easy i made mine with a bit of 50mmx6mm steel with holes drilled in to mount to floor and the gearbox rubber. Any other questions give us a bell as ive been there and done it.
Cheers Andrew
#1 Celica 5 speed conversion
lump_a_charcoal Posted on: 2002/7/5 7:44
hey all - i have a celica box + dellow conv. kit sitting next to my ute - what do i need to convert it over?
will i need a celica clutch?
the box has a crossmember on it that looks datsun, but i havent checked how it lines up yet..
are there any sites on this swap?
its going into a ute (if that matters).
Do i have to cut a hole for the new stick position?
thanks, Linc.
