Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#11
Re: Tempory Fix for Water Leak
supafatto
Posted on: 2013/5/21 14:18
Pepper does the same thing but not recommend it, I'd get some plumbers water paste, remove fitting apply paste and refit fitting see how that goes, any plumbing shop will have something to help
Or even some lucus permiseal
#10
kululadotgroen
Posted on: 2013/5/21 12:23
Very easy fix is to pour a packet of curry powder in the radiator. The curry will circulate until it finds a hole where it will bake into a plug. Don't ask me why it works or how, we drove a A14 for almost a year like that, after a welsh plug sprung a leak, before we pulled the motor to rebuild it.
#9
levey
Posted on: 2013/5/21 10:38
Sorry Sumith but until the cause of the leak is determined I cannot say.
It is not a problem (I think) if you carry spare water/coolant and top up as required before overheating. Maybe also remove the fitting, smear some sealant onto the thread and re-fit before the sealant cures. Hope this helps mate.
#8
Sumith
Posted on: 2013/5/21 9:21
Hi Leavy
I checked the Oil there is no indication of Gasket failure , i will go through them tonight and let you guys know, This has been sat for few weeks did not have time for it since i am planning for a upcountry tour for this week end So doesn't like to Refill Radiator each and every 100 km , so just was thinking about applying gasket maker glue or something similar to avoid that tiny leak, will it work ? thanks regards sumith
#7
levey
Posted on: 2013/5/21 9:08
Just taking a stab in the dark here but Strange backfire and leak near the heater hose connector at the back of the head, could it be blown head gasket?
You could try a little bit of egg white in the coolant as a temp fix but might block more than the leak.
#6
Posted on: 2013/5/21 4:55
I do not known what "plug seal" means.
#5
Sumith
Posted on: 2013/5/21 4:35
Hi DD
I think it is thanks regards sumith
#3
Sumith
Posted on: 2013/5/20 7:24
Hi DD
It is flowing to the Engine Compartment not to the passenger Compartment , Actually it looks it is leaking from the Plug seal It self not from the rubber hoses and connectors thanks regards sumith
#2
Posted on: 2013/5/20 7:00
Is the leak inside the passenger compartment or in the engine compartment? The dashboard (firewall) divides the two.
The easiest fix is to bypass the heater (connect the long heater hose to the back of the cylinder head). It usually solves a leak unless the fitting is rusted out. ![]() You may leave it this way temporarily or permanently -- the engine runs fine either way. Just depends on whether you need the heater for de-misting the windshield. You can view topic.
