#11 Re: Mounting ca18
mrbarista Posted on: 2013/11/10 23:05
def too short for my kev rowley crossmember. tested again last night with a mate to be sure.
#10 Re: Mounting ca18
demacoz Posted on: 2013/11/10 5:42
Bought cortina ones from Bursons .. they work well on my home made crossmember
#9 Re: Mounting ca18
lethal_john Posted on: 2013/11/9 22:34
i had no dramas hey, wasn't way off or anything still had good clearance off the crossmember
#8 Re: Mounting ca18
1600god Posted on: 2013/11/9 20:57
And I know the CA ones are off set. So I think in the opposite position you are able to get an extra 5mm clearance off the firewall.
#7 Re: Mounting ca18
tappet Posted on: 2013/11/9 6:33
I think the cortina ones are shorter than stock ca mounts but also a bit firmer. You may just need to file the crossmember slots a bit further down. they are better than stock mounts providing that there is enough clearance between the sump and the crossmember. A lower center of gravity is always good and lowering will give a tiny bit more clearance for the gearbox.
#6 Re: Mounting ca18
mrbarista Posted on: 2013/11/9 5:07
going to order some ca18 ones
#5 Re: Mounting ca18
mrbarista Posted on: 2013/11/9 5:06
I brought kelpro cortina mounts as suggested on here. still seems to be way off fitting.
#4 Re: Mounting ca18
lethal_john Posted on: 2013/11/9 3:32
i used cortina ones, i think they're round and the same height. do a search on here and you should find the thread
#3 Re: Mounting ca18
1600god Posted on: 2013/11/9 0:31
Also just picked my crossmember up from Kev. Was also curious about this. Kevin designed his crossmember to the standard mounts because that is what came in the front cut. If you find another mount the same height as factory, they will still work. I will be using the factory style ones (not genuine) as they are fully silicon and will provide a good cushion and Kevin recommended to. But of course, each to there own.
#2 Re: Mounting ca18
s1ckdat Posted on: 2013/11/8 23:53
not sure about kev rowley crossmember
but maddat ones use similar to this
http://www.ebay.com.au/itm/Land-Rover ... ories&hash=item3a8623e6f4
