#2 Re: strut bolts wanted with nuts 1200 ute
ddgonzal Posted on: 2013/11/20 20:14
Do you mean the bolts that connect the struts to the steering knuckles?
They are a shoulder bolt. If you use a small hex-head version, standard hardware store shoulder bolts may be used.
Otherwise buy stock ones from Nissan:
40055-H1000 BOLT-KNUCKLE ARM 44MM
08911-64010 NUT-HEX M10 x 1.25
08915-14010 WASHER-SPRING M10
#1 strut bolts wanted with nuts 1200 ute
Datman95 Posted on: 2013/11/20 10:27
After the strut bolts with nuts the ones that connect to the control arm top of the bolt is a half ovel shape need all 4 anyone can help post a photo so i can see if you have the right ones im talking about
