#6 Re: stripped thread help needed
Posted on: 2014/3/16 10:41
Did better found keyserts..... oh the joy. Even with slight thread once you bang in the little tabs its solid. Can yank and load it up like a 14year old with unlimited playboy mags
#5 Re: stripped thread help needed
anths Posted on: 2014/3/16 10:21
run the tap through the hole,use 60/60 loctite on a mild steel bolt,tighten let is go off cut flush and re tap at 8mm it will be smaller but it has no real loadbut will allow you some kind of clamping force
#4 Re: stripped thread help needed
crumb Posted on: 2014/3/2 4:09
Why dont you use that 3bond #OOPS# you used on the sump of the sedan. that was near impossible to remove.
#3 Re: stripped thread help needed
Posted on: 2014/3/1 13:15
Ive got some ange. This bolt also supports the alt bracket.
I swear I was threading this bolt in by hand.
#2 Re: stripped thread help needed
ANGE Posted on: 2014/3/1 12:10
gee mik you and your falcon fetish
how many bolts are left? you could try and use a good sealant like permatex, can get it from supercheap
i swear that stuff is so good you can just about do away with the bolts once its set
#1 stripped thread help needed
Posted on: 2014/3/1 11:18
Any one in melbourne got a m10 or even imperial slightly larger hekicoil kit or timeserts they could help me out with.
Have a falcon and one of the water pump bokts was striped when I got it was 3/8 or m8 sizrd thread that was stuffed. I tapped it to m10 but its striped again after pulling water pump out and putting new one in.
Other wise trying to find ez loc which is a threaded sleave internally and externally.
