Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#11
Re: Re drilling strut top holes ???
bugsie
Posted on: 2014/3/17 8:30
I'll just take the extra 10 out of the plate with a die grinder. If needed I can get 5 out of the bolt holes like the picture shows. I've only checked it with a level and also a plumb bob so hopefully that's enough.
#10
supafatto
Posted on: 2014/3/17 8:17
Those cambertops have a lot of adjustment over s13 ones
#9
bugsie
Posted on: 2014/3/17 8:12
Wow that looks like a lot. Although the 200b lca's have the longer ball joint don't they. You are probably 50mm wider at the bottom than I am so that probably explains a lot. Thanks for the pics.
#8
levey
Posted on: 2014/3/17 8:09
While your at it add some more caster as well to improve handling.
#7
supafatto
Posted on: 2014/3/17 7:57
#6
bugsie
Posted on: 2014/3/17 7:46
I have camber tops but I need a bit more. Looks like yours have more adjustment in them. I was going to just get a die grinder and take a bit more out but didn't know how it would effect the strength of the plate. Need about another 10mm at the top to get the camber right. I have modified lower control arms so they are 25mm shorter than standard. I can now easily fit 15x 7's on the front without guard mods. Are those s13 camber tops?? Mine were cheap ebay universal ones. Didn't know the s13 ones fitted until last week :(
#3
bugsie
Posted on: 2014/3/17 4:00
Makes sense. so u are probably defeating the whole purpose by spinning it. The amount u would make up by redrilling would be lost when u rotate it. ??
#2
L18_B110
Posted on: 2014/3/17 2:59
you won't be able to move the top as far in if you do it that way. The flat sides are closer to the centre of the strut than the points of the 'triangle' are, allowing more negative camber with a flat side of the strut top to the inside of the strut tower.
