#3 Re: transmission problems
ddgonzal Posted on: 2014/4/10 9:57
Yes, could be that
Another thing that can cause is a clutch cable that needs adjustment. Check it. See Clutch Cable
#2 Re: transmission problems
teretonga Posted on: 2014/4/10 9:24
Sounds to me as though your pressure plate is giving up. Inspect that and your clutch disk and chances are that'll be where the issue is.
#1 transmission problems
patydaty Posted on: 2014/4/10 9:15
my 4 speed wont go into 1st and reverse,
but will easily go into gear when off
1st gear is blocked off totally and if i try to go into reverse it grinds
im worried the syncros are busted is it cheap for recondition?
any ideas need the help at the moment
