Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#3
Re: L series into a 1200 ute. what tailshaft do I need?
b310gx
Posted on: 2014/7/27 0:39
If your existing tqilshaft has replaceable uni's, you just need to change the front over to an L series one. The stanza box & the A series boxes are the same length. If the uni's are peened in, like on the Sunnys, a standard Stanza tailshaft from a H165 one 'should' do the job, as I've used a Stanza tailshaft with the front swap to an A series one in a Sunny with a H165. Hope you've got something like this hanging around.
#2
Posted on: 2014/7/23 2:58
H150 auto or h165 auto.
It will most likely need shortening as h165 snout is longer than h145 from memory. You need the auto input shaft as its same as the L series manual box input shaft
#1
Matto1kUte
Posted on: 2014/7/22 14:28
Hey guys getting close to putting a L series in my ute. Only thing im wondering is there a tailshaft that fits straight on? Im using a stanza stumpy box and my ute has the larger h165 diff.
