#4 Re: Bluebird diff center in 1200 ute?
BigD Posted on: 2014/8/6 12:15
Awesome! thank you
#3 Re: Bluebird diff center in 1200 ute?
benny Posted on: 2014/8/5 5:24
If its the H165 centre, its a stright swap. the series III had the H190 rear end
#2 Re: Bluebird diff center in 1200 ute?
cadet1200 Posted on: 2014/8/5 4:29
Can't give you a real technical answer but I think there were three variations in the Bluebird diffs
and I used one from a series II Bluebird in my previous ute and it just bolted in and no shimming or axle changes required.
Have a look at below web page:
http://martybugs.net/DatsunMods/diff.cgi
#1 Bluebird diff center in 1200 ute?
BigD Posted on: 2014/8/5 2:29
Gday, i just wanted to confirm when installing a 3.9 ratio bluebird diff center in my 1200 ute if i will need a shim or not and will the 1200 ute axles be ok? i had a look in the tech section but i cant find and confirm these two questions.
