Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#8
Re: Vacuum advance mystery connector
Datopower
Posted on: 2002/10/29 17:38
Thanks heaps for all your help guys!
I thought it might have been an earth connection point or something similar.. and yeh i couldn't find it in the manual either?? Cheers
#7
phunkdoktaspok
Posted on: 2002/10/29 11:28
Like everyone has said it is just an earth connection point!
Some dizzies have this and some don't! Like most car maufacturers their engineers put things like this just to make sure the dizzy has a ground, but they don't solely rely on this wire as the engine it self is metal and provides an earth connection! As long as your car has a solid earth wire from the battery negative to the body and one to the engine you will have no problems!
#6
1200rallycar
Posted on: 2002/10/29 11:13
its sort of on the extension from the dizzy which the vacuum advance is mounted on/in, i had a look at my brother in laws car today and he had a wire from it to a bolt on the starter motor (as an earth) i asked him and he said it was like that when DatRally built the motor for him so it must be an earth, only one of my a-12's has it on it (1200 one has/120y one hasnt)
#5
mr_nismo4
Posted on: 2002/10/29 9:15
So this spade terminal is ON the vacuum advance, right? Cant say I have ever seen one. There is a spade terminal on the side of the dizzy that has a wire from the factory wiring loom plug onto it, is this what you are talking about?
#4
1200rallycar
Posted on: 2002/10/29 3:57
yeah i wondered what that was too, i think we came to the same conclusion that it was an earth but the whole things earthed to the block so i dunno why they bothered
#3
rgrinder
Posted on: 2002/10/28 4:21
it's a place to hook up an additional ground wire, IF you want to.
unless you really need an extra ground, don't worry about it.
#2
webbs1200
Posted on: 2002/10/28 3:07
I looked in the service manual and it does not show a spade connector on the vacuum advance. Although it does unscrew from the distributor, I can only assume someone put it on as an after thought, for what, I have no idea.
As it is Vacuum there is no need for a electrical connection.
#1
Datopower
Posted on: 2002/10/28 1:44
Hey all,
I just noticed thast on my vacuum advance for the distributor there is one of those brass type electrical tags that a spade type connector can push onto... what is this connection for ? Any ideas ?? Oh it's an A14 too. Cheers You can view topic.
