#7 Re: wanted mild cam suit a12, a12 flywheel and good clutch
Matto1kUte Posted on: 2015/3/15 3:32
K got a flywheel but after a heavy duty stock type clutch. Yea I'm not sure if a heavy duty is the same as a a15 type
#6 Re: good clutch
whalebone-dave Posted on: 2015/3/10 21:52
Pm sent
#5 Re: good clutch
ddgonzal Posted on: 2015/3/10 20:18
A15 clutch is heavier
Clamping Force
* B210 A12: 616 pounds
* B210 A13: 694 pounds
* B210 A14: 794 pounds
* B310 A12A: 573-684 pounds
* B310 14/A15: 739-849 pounds
As with Nissan, aftermarket clutches are heavier duty, requiring increased pedal effort. So aftermarket A12 clutch may be the same as the heavy A15 spec.
The most heavy-duty clutch from Nissan are:
* 30210-H5220 420KG (926 lbs) NISMO HIGH-PERFORMANCE PRESSURE PLATE
* 30210-A1200 550KG (1213 lbs) NISMO HIGH-PERFORMANCE PRESSURE PLATE
#4 Re: wanted mild cam suit a12, a12 flywheel and good clutch
ddgonzal Posted on: 2015/3/10 20:11
You could use a Datsun 1000 camshaft. It is milder than an A12 cam.
#3 Re: wanted mild cam suit a12, a12 flywheel and good clutch
Datman95 Posted on: 2015/3/10 12:04
A new clutch kit is only 70-80 buks its a clutchpro brand its a good brand
#2 Re: wanted mild cam suit a12, a12 flywheel and good clutch
Matto1kUte Posted on: 2015/3/10 11:28
Do the stock a15 vanettes have a better clutch? Should I go for new vanette one? Sorry budget is low :\
#1 wanted mild cam suit a12, a12 flywheel and good clutch
Matto1kUte Posted on: 2015/3/3 12:53
Hey guys just chasing a very mild cam, a12 flywheel and a decent clutch. Something to suit turbo a12 application. Please pm me with details thanx :)
