Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#4
Re: forced induction: intake bolts sufficient?
smellsofbikes
Posted on: 2015/4/17 18:47
Cool, thanks! I can totally manage this.
#3
Posted on: 2015/4/17 6:47
#2
1200rallycar
Posted on: 2015/4/17 5:32
when the two manifolds are mounted the bottom studs should have large thick washers, that way they hold both intake and exhaust. the studs on the under side sit in between a relief in the intake and one on the exhaust, it's a shared stud for both manifolds
and yes, the standard mounting system is plenty for boosted application as proven by many here.
#1
smellsofbikes
Posted on: 2015/4/17 5:28
Are the two bolts above the intake manifold enough to keep it sealed with less than 10psi boost? Would making secondary clamps that attach to the exhaust studs and press against the bottom of the intake manifold flange be a better idea?
