Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#6
Re: Help me diagnose this idling issue
a12dato120y
Posted on: 2015/4/23 14:02
good to know you got it solved
#5
FaizanAhmad
Posted on: 2015/4/23 13:55
I changed ignition coil and issue is resolved now. Thanks everyone for help.
#4
FaizanAhmad
Posted on: 2015/4/20 14:24
Thanks, i will checkout ignition system and post here if it solves the issue.
#3
a12dato120y
Posted on: 2015/4/20 12:16
sounds definitely like ignition issue i have had ignition systems play up in the heat such that the engine will stall and start and drive perfect when it cools down.
Could be ignition coil breaking down or any ignition related components. Also can be your ignition wiring frayed, loose or corroded. also check your ignition switch could be shorting out inside but seems unlikely as they seem to burn up into smoke when they go (at least it did for me)
#2
Posted on: 2015/4/20 11:48
Hi Faizan,
Unfortunately the video wouldn't play on my Android 4.1 browser. But it sounds like heat lock. Is the fuel line running near the exhaust? Or perhaps a loose wire at the coil, resistor or inside the distrubutor.
#1
FaizanAhmad
Posted on: 2015/4/20 11:10
Hello Everyone.
I'm having this issue with my datsun120y 1974 for quite some time now.
it happens only in summers after a run of like 5km or 6km. Engine loses power turns off and start again by itself.
I've created video of issue.
http://i120y.tumblr.com/post/88020230 ... -wrong-with-my-carb-today
Let me know if anyone know what's wrong.
