#10 Re: reverse rotation turbos for the A series
D Posted on: 2015/11/12 13:33
not as direct for drawthrough which is essential for efficiency
and would look so compact and neat making the setup a breeze
#9 Re: reverse rotation turbos for the A series
ddgonzal Posted on: 2015/11/12 3:42
Why not just use a regular turbo and position it 180 around?
regular turbos don't seem to need convoluted piping
#8 Re: reverse rotation turbos for the A series
D Posted on: 2015/11/12 3:31
locally here they were released as the holden Gemini :)
Heavy but solid offerings with good suspension and bullet proof engines
http://www.shannons.com.au/club/enthu ... arage/1979-holden-gemini/
http://www.shannons.com.au/club/enthu ... arage/1978-holden-gemini/
The reverse turbos would suit these type of manifolds for a cleaner direct into the manifold install
#7 Re: reverse rotation turbos for the A series
ddgonzal Posted on: 2015/11/11 19:55
Do you remember the 1981 Isuzu I-Mark diesel? It got incredible fuel economy and was sporty to drive (albeit a little slow). If only some company now would make an inexpensive rwd thrifty car like used to be available (1200s, I-Mark, etc).
#6 Re: reverse rotation turbos for the A series
D Posted on: 2015/11/11 13:28
Yes thats correct it will facilitate the inlet side to make it as compact as possible when using either a stock manifold or custom inlet
Im not keen on spending that much would prefer a modern fwd diesel turbo with the same placement or rotation etc
jpg  AA reverse rotation turbo hks-7460r.jpg (15.52 KB)
737_5643420d2b266.jpg 350X197 px
#5 Re: reverse rotation turbos for the A series
LittleFireyOne Posted on: 2015/11/10 20:38
DD, it allows for a straight shot towards the head instead of curving something chronic
#4 Re: reverse rotation turbos for the A series
Dundee1000 Posted on: 2015/11/10 13:11
I've seen mirror image turbos for a pair on a v8...
#3 Re: reverse rotation turbos for the A series
ddgonzal Posted on: 2015/11/10 8:11
how does it simplify turbo'ing a 1200?
#2 Re: reverse rotation turbos for the A series
zigmondo Posted on: 2015/11/10 7:14
Does this just mean that the compressor is on the opposite side of the turbine ?
Don't get it unless different orientation options are the key.
dp
#1 reverse rotation turbos for the A series
D Posted on: 2015/11/10 6:08
just wondering if anyone knows of other reverse rotation turbos?
they would simplify the setup for carb draw through apps
eg.
http://garage.redlinemotive.com/story ... urbo-upgrade-for-evo-8-9/
